Has anyone tried running larger rear wheels on a talion or smaller fronts on a kraton? E.g. take the fronts off a talion and swap them with the fronts from a kraton. This would mess with the diff values a bit. Effectively giving you potentially more push from the rear vs a faster turning smaller front wheel. This is on my talion 6s running 6s 100c batts. I have so much power that all wheels are spinning on all surfaces anyway. So its more a matter of grip over what power is being sent to front and rear. Any thoughts on this. ? Rear tires are 150mm backflips. Fronts are standard 105mm talion katar.
