Hi all
i purchased a Limitless V2 and a HobbyWing max 6 combo and fitted it all up. The 4985 motor has a 5 mm shaft and the limitless has the standard 39T spur.
I’m in Australia and cannot purchase a Mod 1 pinion any bigger than 30teeth and of course it will not mesh with the 39 spur and I can’t cut any of the motor mount to let it slide in further as the adjustment screws wouldn’t go in. 32teeth is the smallest that will work.
does anyone know if a bigger spur gear say 42 teeth will fit in the limitless or can I use another sort of pinion like 32 pitch or something else.
for now I have an expensive ornament.
any help appreciated
