- Charlotte NC
- 4x4-Mega
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Mojave
- Mojave EXB
- Notorious
- Outcast 6s
- Senton 3s
- Talion
- Typhon 6s
- Typhon 3s
Okay so I have 2 10th Anniversary Outcast trucks #102 and Mint #469.
#102 is next up on the building block. It's a super clean truck with only a few runs on it but it's not going to be a collector truck like #469.
I'm planning on building it and I'd love to hear your thoughts on the direction you'd take with it...
(Build Option #1)
Outcast exb xl. With a Lightweight Kraton Speed Chassis build and v5 / exb suspension, Exb diffs, scorched titanium driveshafts, BasherQueen carbon towers, aluminum suspension blocks, Hardened hinge pins my normal big air setup. (I prefer the kraton chassis in the air over the fairly unstable swb).
(Build Option #2)
Full Titanium swb build, Scorched Titanium swb chassis, exb diffs and suspension, titanium exb towers, titanium center driveshafts, BasherQueen carbon brace, aluminum suspension blocks Hardened hinge pins.
(Build Option #3)
M2C Full Swb lightweight speed chassis build, braces, exb diffs , exb suspension, BasherQueen Towers, center brace, aluminum suspension blocks and Hardened hinge pins.
I will be running a Reefs Raw500 servo, Max6 1650kv combo or a 4092 1480kv setup on all options.
Also has anyone been using rpm arms with v5 / exb towers ? I'm not a huge fan of the flex in the rpm Outcast/ Kraton arms, in the past I bent so many axles it became ridiculous but I do have a set just laying around I just wasn't sure the geometry would work correctly.
I'm going to end up doing whatever makes me happy but I'd still like to hear what setup others would be interested in. Keep on bashing and thank you guys
(Build Option #1)
(Build Option #2)
(Build Option #3)
