You need a 17mm hexed wheel for starters. With ZERO offset wheels. So it is not that simple.
Belted tires are almost a prerequisite.
But 1/8 Buggy zero offset tires/wheels have been used for groomed dirt oval running on the Infr.
Just need to raise the body/ body posts a bit. Remove the front splitter for the dirt running. If staying only on Pavement need a "belted" street tire.
Not quite sure what your plans were with those 2.8 Banditos. Defintely not for speed runs I hope
I already have 17mm hex and I’m just want some different wheels. I got the hoons instead tho. Got banditos for my big rockYou need a 17mm hexed wheel for starters. With ZERO offset wheels. So it is not that simple.
Not quite sure what your plans were with those 2.8 Banditos. Defintely not for speed runs I hope.
