Could be charger settings. If you can show the charger folks should be able to see if this is the case.Using 2-3s 7600mah 50c lipos
venom pro lipo chargerCould be charger settings. If you can show the charger folks should be able to see if this is the case.
This is the batteries im running.Could be charger settings. If you can show the charger folks should be able to see if this is the case.
after i charge them they hold at 12.2-12.3.
