Mojave Max 6 Esc mounting
GunitSamba
Norfolk, UK
  2. Mojave
Hi.
What is the best way to mount the MAX 6 ESC to the standard plastic mounting plate?
Detailed description with with or without pics greatly appreciated.
Many thanks.
Several options:
1. Drill holes in the plastic plate for the screw locations on the MAX6
2. Print a plate and screw it onto the factory mount:
Aside from the factory plate, there is the m2c mount:
and Basherqueen mount:
The Basherqueen mount allows for a perfect fit without having to cut anything. And it has an answer to “where do I put the switch “
the mount has a tap to install the switch.
Thanks for the advice all.
Unfortunately aftermarket is out of the question at the moment.
I have cut the plastic tab off and will attach tomorrow with the stick foam.
I will also attach 2 cable ties on either side of the ESC, 1 going over the caps and the other going over the connector side.
Thanks again.
