The timing Arrma puts their cars out with is a little hot, imho. I'd lower it to 15° or even try 11.25°. You won't notice that much difference in terms of performance but it will definitely lower your motor temps a few degrees.The new kraton v2.5 motor timing is set to 22.50 degrees!
It's kinda high I think.
Is a lower timing better for the motor, heat wise?
I know it will run somewhat slower.
Thank you.
It's in the manual, actually:Where did you find that the timing was 22.50? I know the stock 150a ESCs were 22.5. It doesn't even look like you can adjust timing on the 120a ESCs in the 4s trucks?
