Andrew price
- Typhon 6s
Hi guys I'm looking for a direct fit motor heatsink with fan. For a v4 6s notorious...
Great thanks ?The yeah racing dual fan should fit
PowerHobby dual motor and heatsink fans are also an option.Hi guys I'm looking for a direct fit motor heatsink with fan. For a v4 6s notorious...
Cheers ?PowerHobby dual motor and heatsink fans are also an option.
Don’t forget to get a Y connector so that you can power up your fans. Strangely one powerhobby set came with it and the other didn't. Luckily I had one laying around. I guess they forgot to put it in the package. Actually two of them had it and one didn't ?.Cheers ?
Lots of knowledge from good people here. I try to help out with my limited experience ?.Cheers ?. This arrma forum is great.
PowerHobby on my Typhon 6s. It looks pretty much the same ?like @Overpowerrc said, can’t go wrong with the yeah racing setup ??
View attachment 78814View attachment 78815
Looks just what I'm after. Cheers ?like @Overpowerrc said, can’t go wrong with the yeah racing setup ??
Hobbywing 44mm dia. Heat sink with 50mm x 50mm Fan fits well on the Arrma BLX 185 / 2040kv motor I found, but you need to add a 1.5mm thick thermal pad underneath to make it all work a treat. Not exactly ‘direct’ fit but really effective and cheap....my motor does get above the high 40’s now, whereas it used to go up to 80C when run hard in summer.Hi guys I'm looking for a direct fit motor heatsink with fan. For a v4 6s notorious...
