Wes13
- 4x4-Mega
- BigRock
- BigRock 4x4
- Granite
Can you explain?No don’t change motor timing unless you wanna burn up a motor.
I have a firma 130 on the way, didn't even know it has options like that
What rocket fan do you run on the firma 130? 30 or 40mm?Fellas... @jondilly1974 you may not run the 3S anymore... @Outcastblxnut @crimsonfancy
With all the runs done above posted with the Big Rock, etc.....did any of you have an ESC where you could change the timing....for the Granite/Big rock 17T or 18T etc....did any of you change the motor timing down to counter the heat?
I'm not 100% what deg of timing would be right but I read so much that stock motors have higher timing numbers so more heat...
I run the Firma 130A on the Big Rock it has a motor time default at 15deg with lower options of 11.25 and 7.50. I have a 17T pinion that I want to install. Been running Rocket aluminum fans on motor & ESC so during the summer I've had NO thermal cuts-offs...
