The grease lord once again is back. I wanted to share a bit of my experience with the grease Red N tacky from lucas. They claim to be water proof and have an anti seize additive for more surface coverage. I can say that is true and not true at the same time.
let me start with the anti seize additive and protection against wear. For the main differentials GearS its perfect gears look like new on my 6s trucks. The grease turns slightly dark but i think that is completly fine. The grease smells like candy too!
the part im having an issue with is the waterproof part. Its almost a complete lie. I was victim of a rear diff case auality issue where the diff screw holes were not deep enough to seal the gearbox. And i run my mojave in the snow and the main gears run the lucas grease as it main lubrican and well. The diff screws were all rusted out i didnt know why but now i know why. I though it was maybe bad luck.
Before i discovered that issue tho i cleaned bearings who spun like new once cleaned and packed them with red N lucas and shoved them on my center and front diff. Keep in mind the stock bearings with the stock grease never had a single bearing seize except one in the center diff.
one run in. If you have been fellowing me i made a post mentioning why my truck was vibrating like Crazy in the front. Took apart the front section everything was fine closed it back up. Today decided to check again after i finished rebuilding my rear diff with marine grease this time for the bearings. The diff outdrives from the outside were packed with black grease bassicly the red n lucas turned black. Made my truck run by itself in the bench with the remove and removed the grease until i was able to see the inner bearing race and check for spin. One was spinning and the other one Was not. Remember i packed them both with the grease prior to the run. Removed the front diff and sure enough the beraing was seized hard even wd40 when the truck was spinning didnt free up the beating.
The bearing wasnt rusted really grease was still there but it was stinking like dog poop. Like the bearing that still spun free smelled like candy the other one stinked hard.
i see a lot of people recommand this grease for their rcs its a good grease against wear but for bearings and water its a big NO. I took 3 old bearings packed them each with 3 different greases. Multi purpose grease, red n tacky and marine grease. All under a bucker of water for a Week. Result red n taky rusted and release an orange paste into the water the mutlti purpose also rusted in the outside and both were not happy to spin. The red n lucaS was stinky. And the marine grease well the outside rusted a bit but still spun like it didnt care.
did another test remove most of the grease i could so that wouldnt be packed anymore dropped down in water a few more days again marine grease didnt give a dam hell vs the other two who got worst. They still spun tho. Left them to rest so they can dry and red n tacky seized lmao. Multi purpose still spun. Its rly weird because Theres absolutly no visible Rust to the naked eye on any of those bearings in the internals. Maybe the anti zeine additive became a locker additive?
anyway just wanted to share my experience on the candy smelly grease who is know as red n tacky.
