Bellyslide
New Member
Just posting my mega typhon running 6s so far have gotten it up to 87mph
All I've done was put the high speed drive shaft bearing. And I've ran probably 40 battery packs or more through it. Only stripped the rear diff once. Oh yea I've done the .08 mod and motor mount upgrade. Runs a 26t they are strong as could be cause I'm not easy on it at all. I love arrmaWoah! What kind of upgrades did you do to make it withstand 6s?
Cool! Maybe I should upgrade my Typhon 3s to make it capable of 4s.All I've done was put the high speed drive shaft bearing. And I've ran probably 40 battery packs or more through it. Only stripped the rear diff once. Oh yea I've done the .08 mod and motor mount upgrade. Runs a 26t they are strong as could be cause I'm not easy on it at all. I love arrma
I need to get some hoons I have shredded every tire that I have put on.l, but I am running duratrac bandit's and they have a bead lock but I have also glued them on. They have came out of the bead lock once before the glue. But now they don't. They do balloon a bit thoughWhat tires you use with 6s? Do you use belted tires?
According to the venom speedometer it also has a odometer it says I've gone 27 miles since installed I probably have gone closer to 50 miles on the setupAll I've done was put the high speed drive shaft bearing. And I've ran probably 40 battery packs or more through it. Only stripped the rear diff once. Oh yea I've done the .08 mod and motor mount upgrade. Runs a 26t they are strong as could be cause I'm not easy on it at all. I love arrma
