NewKratonuser0311
When you replaced the center diff and installed the arrma aluminum center diff did you have to shim anything. I upgraded to aluminum center diff and hot racing and I have way too much back and forth play with this new set up. What’s the best way to resolve it.I did a few more things on my Typhon 6S over the past couple of weeks.
The Typhon is such a pleasure to drive. I think it's now pretty close to an ideal state for my type of bashing (for now...)
- Finally received my Mojave shock springs for the rear so both front and rear are now using Mojave springs - 800 cst front, 1,000 cst rear
- Replaced front and rear diff with the Arrma metal diff cases - now running 50k in the front and 10k in the rear
- Put in a GPM aluminum center diff support
- Also put in a Hot racing steering link to reduce some steering slop
- The Duratrax Banditos became completely bald after around 25 - 30 packs so put on a new set of wheels, which are a bit smaller than the Banditos, so I upped the pinion to 18T
View attachment 111035View attachment 111036View attachment 111037View attachment 111038
