need help with gear
if you’re still running the stock motor mount then the least amount of teeth that will fit is 71t I believe.
I’d consider switching the diffs to 43/13 (Typhon diffs) and going bigger on the spur to like a 46 or 48t and uses something like a 25t pinion to start. This will be good for about 55mph on 6S. Street bashing for me was best around 40-50mph.
When it was faster it just ate through the tires as there was a ton of wheel spin.
