ArrmaNero
So yesterday both of my front tires finally died, all the foam in them just went flying during hard pulls, and I'm looking for a replacement. After some searching I found these Louise MT-Pioneer belted tires, which are cheaper and more readily available then PL Trenchers. However, these tires are A LOT bigger then the stock DBOOTS (170x106mm vs 165x87mm). Do you guys know whether this will have a very big impact on the steering D/R? the Nero isn't very maneuverable as is. I also wandered if I have to change gearing when running these bigger tires, and if so, to which pinion gear?
