MikeTrout
I need some of you guys, and gals help with my current situation with my 6s Infraction. I just received a warranty replacement 150amp brushless ESC as my previous 3 month old ESC burned up. Truck is mostly stock other than 20T pinion for speed runs, diff fluid, and metal center diff casing. Using 2, 3S, 5200, 80C lipos with ec5 plugs. The new ESC has IC5 plugs which Im told are compatible. So hooked up everything and mounted it just like original ESC was mounted. I did the bind and calibrate on it. Right when I finished and was testing throttle, brake, and reverse I smelled something burning, then noticed smoke coming from the truck. I immediately powered off the truck and transmitter and unplugged the batteries. I started feeling around to see if anything was hot or looked burned and I could not find anything. Has anybody experienced this or know what I might need to check that would cause this to happen? I have attached some pictures 2 trillion show how everything is hooked up and where my stick positions are for the transmitter. If anyone has any input I'd love to hear it thanks in advance.
