New Hobbywing 12s release 300a
rccar4life
  1. Limitless
  2. Kraton 8S
  3. Kraton EXB
  4. Mojave EXB
  5. Talion
  6. Typhon TLR
70 size , how to fit this in Arrma Kraton 8s ?
https://www.hobbywingdirect.com/products/ezrun-70125-motor
Specification
Model
70125SL-560KV​
PN​
30402850
Pole​
4​
KV(No-load)​
560KV​
R. (Ω)​
0.0050​
Current No-load(A)​
3.6
Motor D.&L(mm)​
70mm (2.760in) / 125mm (4.921in)
Shaft D.&L of the projecting part(mm)​
8mm (0.315in) / 30mm (1.181in)
LiPo(S)​
8-12S Lipo
W (g)​
1995g
Applicable​
1/4th, 1/5th Heavy-duty Off-road, Truck.
Best match with​
MAX 4 HV ESC
Look at the WEIGHT
lol
https://www.hobbywingdirect.com/collections/ezrun-max4-system/products/ezrun-max4-esc
World's Largest : 1/4 - 1/5th MEGA RC vehicle
Off-Road, Truggy, and Monster
Bottomline
  • The ESC uses a special process, coupled with an innovative waterproof design, to increase waterproofing and dust-proofing performance in different climates. It is easy to deal with the harsh conditions containing sediment, ice, snow, and water accumulation.
  • Built-in ultra-powerful switch mode BEC with a continuous current of 10A, an instant 25A, and support for 6V/7.4V/8.4V switching, supporting a wide range of powerful and high-voltage servos.
  • Equipped with the most advanced and safe electronic switches. The traditional mechanical switch protects and prevents dust, humid and other harsh environments, contact rust, and violent impact (such as flying slope landing)
    caused by the automatic closure of mechanical switches and other issues.
  • Built-in fire-proof circuitry to protect the battery plug, while effectively avoiding damage to the case from electrical sparks (fingers).
  • Multiple protection functions: battery low voltage protection, ESC and motor overheat protection, signal loss protection, and current protection.
  • Support LED program card, LCD program box, OTA programmer (Note: optional) to set the parameters of the ESC.
  • Real-time data recording function to view various running data on the HW LINK app using the OTA Bluetooth module.
Specifications
MAX 4 (HV)
Scale Vehicles1/4 - 1/5th
Cont./Peak
Current
300A/2000A
Motor ModeSensored and sensorless brushless motor
Input6-12S Lipo
Motor LimitWith 12S Lipo: KV≤600 70125 size motor
BEC Output6V / 7.4V / 8.4V adjustable, continuous current 10A (Switch-mode)
Programming
Port
Share with Fab interface
Switch ModeElectronic Switch
Capacitor
protection
Yes
WaterproofYes
Size (L.W.H)
mm
125 x 85 x 61.7mm
Weight (g) 775.4g
Motor recommendation
HEHEHE
O-M-G
This is for “real” 1/5 scale stuff. I’m sure someone will stuff one in a Kraton or Outcast but would be right at home in a Dbxl or 5t/5b build.
Specs don’t seem too far off from a castle combination. Makes me just wanna go and get one of those now!
Would need the chassis milled out and the center diff flipped 180 degrees and it will fit.
