Hello!
Please be gentle, I'm new here and new to RC cars too but I'd love some help before the long easter weekend.
Last week the motor on my brand new Senton BLX died as the bearing collapsed after 5 days and 7 batteries' worth of race time.
I sent this back to Wheelspin and they sent it to the distributor for a replacement, so God knows when I'll get a replacement back.
Wanting to get back to racing asap I went and ordered a Hobbywing EZRUN 3652SL 3300kV G2, to also have as spare if this were to happen again.
I just received this > installed a spare 19T-32 pitch pinion (factory is 20T) > mounted it.
I of course made sure it was all well aligned, tightly screwed and spinning freely and first test with wheels off ground seemed fine.
I then put the Senton on the ground to give it a quick spin, and here is where I have problems... the motor runs fine and quick for a few seconds/meters, but then if I stop it struggles to move again.. I can see the shaft trying to rotate but it's as if the motor has not enough juice? The esc does not beep, as it did when the factory motor died (and the pinion was just stuck).
The motor is barely warm to the touch, so I have no idea what I am doing wrong here.. is it a motor/esc compatibility issue? Is the motor too weak or badly geared? Do I simply need to recalibrate and change some settings on the esc (this is currently set to factory settings as out of the box)?
Please help and thank you!
