stangken
- Kraton 6s
- Outcast 4s
Just finished installing Talion 6s shocks on the 4s Outcast. I was able to swap over the stock 4s springs.
Things to note:
-Stock shock leaked without me taking the truck outside. It started leaking after driving only 20 ft in the house. I was correcting the steering inside as this is my wife’s mother’s day gift and I wanted it sorted out when she opens it.
-I needed to use 3 washers on each upper shock mount to eliminate the slop as the stock shock caps’ mounting area is wider.
- I needed to add a couple washers on the lower front shock mounts as the front half-shafts were rubbing on the spring perch.
I’ll let you know how it drives this weekend when the wife opens it. Also, I painted an F100 body for her
Things to note:
