enginerdkraton
New Member
Hey all! Relatively new here. I recently upgraded from a brushless converted Senton Mega to a Kraton 6s. It’s safe to say they’re a bit different. However, I took the Kraton out for a very light bash (max 4 ft jump) and the pinion already came loose and the set screw was nearly crushed by the spur gear. Luckily I was able to get it out and get the pinion gear off. So I have 2 questions:
1. Is this a normal occurrence of the pinion gear not being tight enough? Or did I miss something and should have tightened it down when I first got it?
2. Are the set/grub screws something you can pick up at your local Lowe’s/Home Depot? Or are they RC car/Arrma specific?
keep in mind I’m extremely new to the hobby and ready to learn! Thanks in advance
