Jeffvanuden
So I pulled the motor completely out and it spins just fine when not hooked to the front and rear dog bones diffs so probably one of those how do I tell which one is the bad oneHi I have a outkast 6s blx185 stock. Motor and ESC I'm getting steering but no throttle tried resetting the esc and everything else I can think of but no throttle some times when I pull the throttle the drive shaft just vibrates a little but then nothing again
But if I hold it off the ground wheels kinda spin
I picked up the front and the rear and rolled it and the tires roll on both sides so does that mean the center diff is badPick the front or back of the truck up and move it, and vice versa, after that grab a wheel and spin the opposing one..
