quiznatodd bidness
I recently changed pinions around and forgot to loctite the set screw on the motor shaft. I ran a good 10-15 mins before I heard grinding. Turns out the pinion came loose and the tiny snap ring on the end came off and pulverized itself on the gearing. I replaced the ring and loctited this time, however, the snap ring/retaining clip again came off and ground around after about 5 mins. This time the pinion is still locked down.
Anybody else have issues with that?
