I am new to RC vehicles...by now you guys have lots of experience with both models, Kraton 4s v2 and 6s v5 due to my nil experience I would like the one that has minimum upgrades, repairs, maintenance, etc. I am not to much into the field of bashing but my truck must be able to handle it. With all this being said I am really considering the Kraton but if you guys think I should consider another model pls share, let me know what you guys think.
Kraton 4s v2
-longer hinge pins AR330731. Direct fit.
Originals have the end rounded and tends to lead to broken chassis. That part has went Back order. You might be able to find it at hobbyshop tho.
-better hinge pin brackets front and rear to pair with ARA330731
-better servo saver. Few options availailable
-adding preload to the tower to tower brace. To increase the chassis regidity
Kraton 6s v5
-rpm skidplate or bumper for the rear
-exb front bumper with 3d printed spring
-3d printed wing mount
-optional EXB diffs(3) with the open diff kit
-aluminum chassis braces with longer mounting screws(if you end up breaking the screw head in a crash you have a way to remove them from the other side)
-aluminum hot racing rear bulkhead.
-m2c outdrives for rear and center diffs
Those are what i have on my trucks. They have been very durable without breaking the bank. The RTR chassis on the v5 are very good. I have the exb and RTR and both are holding up. They have both bent once because of the Tower to tower brace. The slightest of nose impact the rear of the chassis near the gearbox will bend. All the energy is sent to that pivot point. That bar was added after extreme bashers/influences started doing this out of metal tubes and zipties. It was a good idea but poorly executed from arrma. But they did it right on the 4s line by adding a ruber damper
