Limitless Project Overkill - The Quest for 150
By 150, did you mean 150 MPH or 150$, cuof umz you've way surpassed one of um.
I'm gonna let you know that the Scorched's CF Torsion bar was 100% worth the money.
Damn you... I've now caved and bought one...:ROFLMAO: I can actually use the platform for a battery for lights and motor fan
the total is creeping more towards 150K :p - currently @ $4,500 :eek:
Bit more work done on car…
Scorched torsion bar has arrived..
MCi custom graphics installed..
Absolutely gorgeous build, man. Well done! Good luck and Godspeed on your run up to 150. I bid you little to no carnage. That thing’s too pretty to go out in a blaze of glory.
not much to report on the build of late.. been messing with a Tomahawk build
added spacers to the centre spool to remove any play
spool is a 39T Saga Gear, so changing it for a different size will be simple.
Have also ordered 2x Onyx Modified LHB 11.1V (3s2p) lipos for 6s running
