Hi Everyone, here is my Limitless V2 Build log.
After spending countless hours on YouTube I've decided its about time to experience the adrenaline rush that is speed running.
I've watched pretty much everything on Raz's channel including his excellent build series, and most of the stuff on James McCoy's as well (as these two are primarily the ones responsible for where I am today posting this).
I've browsed the build logs on this forum and have absorbed loads of information from this goldmine of a site. thanks all that have posted information on setups and how to proceed as the information has been invaluable.
Right.. onto the build.. As I've said my initial goal is 150MPH. with the items I've picked up in the last month this hopefully won't be a problem.. later on down the proverbial road I will probably look for higher numbers.. but you have to learn to walk first..
Following advice given to others I'm starting on 4S, trying to learn the car and gradually building up speed. I know I might have to move over to Foams closer to the 150 mark.
I might also pickup a couple of Onyx 3's packs as well to interim on 6S (depending on how I get on)
my primary task (apart from the build that is) will be to find a suitable local road to speed run, as the UK's roads are notoriously bad (and the weathers not that great either).
right enough waffle.. onto the parts list and pics..
(it would probably be easier to list what I haven't bought from Scorched, Perfect Pass and GPM, rather than what I have got)
Arrma | Arrma Infraction roller V2 |
Arrma | V1 Pivot ball (4) |
Castle | Castle Motor 1717 1650kv |
Castle | Castle Mamba XLX2 , 8S, 33.6V ESC, 20A Peak BEC |
Castle | Castle Link V3 USB Adaptor |
Castle | Castle Link castle connect |
Ebay | 8mm to 6.5mm Adaptors |
Ebay | Custom Painted body |
GPM | Aluminum 7075-t6+Stainless Steel Adjustable Front Steering Tie Rod |
GPM | Aluminum+Stainless Steel Rear Upper Arm Tie Rod |
GPM | Medium Carbon Steel Front CVD Driveshaft |
GPM | Medium Carbon Steel Rear CVD Driveshaft |
GPM | Aluminum Front Upper Arms -red |
GPM | Aluminum Tie Rod+25T Servo Horn - red |
GPM | Aluminum 7075 Wheel Hex And Wheel Lock - GPM MAK010 |
GPM | Aluminum 6061-T6 Knuckle Arm Dust-Proof Retainers |
GRP | Tyres GTK03-XM3 - 20 Spoked FLEX Silver Wheel (8) |
GRP | Tyres GTK02-S5 - 20 Spoked FLEX Silver Wheel (8) |
Onyx | O.P.S competition packs D/S 6500mah 14.8V (4s2p) (2) |
Perfect Pass | Aluminum Arms |
Perfect Pass | Perfect pass launch control |
Perfect Pass | Perfect pass batwing |
Perfect Pass | Perfect Pass Servo |
Perfect Pass | Perfect pass speedrun springs |
Perfect Pass | Perfect Pass V2 drivertrain |
Perfect Pass | perfect pass carbon fibre kit |
Perfect Pass | Perfect Pass QS8-V2 Anti - Spark Connector Set |
Saga | 5mm Mod 1 Pinion gears 34T |
Saga | 5mm Mod 1 Pinion gears 36T |
Saga | 5mm Mod 1 Pinion gears 38T |
Saga | 5mm Mod 1 Pinion gears 40T |
Saga | 5mm Mod 1 Pinion gears 42T |
Saga | M5 screw 8MM Mod 1 Pinions gears 34T |
Saga | M5 screw 8MM Mod 1 Pinions gears 39T |
Saga | Battery Straps x4 300mm |
Scorched RC | Carbon Chassis V2 |
Scorched RC | Battery mounts x4 |
Scorched RC | Roto-lok Motormount |
Scorched RC | 7075 Rear Hub Carrier Pair - Ceramic bearings |
Scorched RC | Body retainer / Side Body Post |
Scorched RC | Steering Knuckle Front Hub Pair - Ceramic bearings |
Scorched RC | Steering Bell Crank - Ball Bearing Upgrade |
Scorched RC | Spool / Spur Shim spacer kit - For 8mm spools |
Scorched RC | Front Chassis Infills for Arrma Limitless |
Sky RC | GSM020 Performance Analyser |
