- SE PA
- Kraton 8S
- Kraton 6s
- Mojave EXB
- Outcast 6s
- Talion
- Typhon 6s
Wd40 speeds up part rusting? Come on now...I’ll have to experiment. I’ve been putting that poop on everything for 40years...
I use WD40 to clean nitro air filters, then follow up with dawn dish soap. I know, I'm a cheap SOB. However, after saturating the filter with WD40 and when I go to wring it out, it looks like it has a light grease in it. Kind of like white lithium goo that gets all over. Then I use the dawn to wash that out and they end up looking like new.I'm gonna guess you have a rusty bike chain?
Next time you have a squeaky door - Pull the hinge pin, wipe all the old grease off, re-install, and put WD40 on the hinge. It will be quiet for about a month, then squeak worse than ever. If you don't wipe the old grease off, the WD 40 will just move the grease around (trying to clean it), and it will take a few months for it to start to squeak again. The experiment fails, but it fails because the good grease gets back to where it is needed, not because WD40 is doing any lubing...
I like where this thread is going. Is it too early for bourbon?? ?I'll just go back to drinkin and bashin.
