Reubydoobe
Reuby Doobe
- Mojave
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
Anyone else had the c clip on the rear dif bearing come out. Mine did when a stone got jammed up in there . I'm thinking the plate could be used upside down to stop stone's sitting in the brace/support. Or even better arrma could fit a cover to the hole unit like the one in the picture.
I've fitted a new c clip but had to strip the rear from the chassis to do so as the plate is under the rear drive shaft. I can only see it happening again.
