craig72
- Kraton EXB
- Nero
- Talion
- Typhon 6s
I've gone through hell with my Kraton v4 gearboxes.. it's always something with them!! Either screw wholes tear up or just full on snap blah blah blah you always have to be careful about every screw you put in there in order to not strip or break something.Apparently at some point my front gearbox took a beating and I just now realized it. Any recommendations for a good replacement? You just use stock or is there something better? It's a V3 running stock ESC/motor for now, but looking to upgrade it to Max6/4985 can in the near future.
Thanks gang.
View attachment 102717View attachment 102718
Shim as you would with the stock one. The HR one's are amazing. I was worried they'd be heavy, but was shocked at how light they are. Remember to use thread lock everywhere.Just ordered two of the HR gearboxes. Did I read correctly that the differential needs to be shimmed inside of the gearbox when using the HR ones? If so, what shims do are you all using? Thanks fellas.
roflAlso, if you’re using that little plastic thing that Arrma calls a front bumper - might be worth adding an RPM or EXB bumper to keep the front diff case from taking hits.
rofl
I thought the same thing about the "bumper" after I took a little nose dive.
"Really Arrma? This is a front bumper to you?"
Same thing happened to me today and looking to upgrade the annoying buggers! The hr ones look nice! Which ones did u go for in the end?Apparently at some point my front gearbox took a beating and I just now realized it. Any recommendations for a good replacement? You just use stock or is there something better? It's a V3 running stock ESC/motor for now, but looking to upgrade it to Max6/4985 can in the near future.
Thanks gang.
rofl
Same thing happened to me today and looking to upgrade the annoying buggers! The hd ones look nice! Which ones did u go for in the endApparently at some point my front gearbox took a beating and I just now realized it. Any recommendations for a good replacement? You just use stock or is there something better? It's a V3 running stock ESC/motor for now, but looking to upgrade it to Max6/4985 can in the near future.
Thanks gang.
To me exactly the same happened in the rear.
I am thinking of buying these from Vitavon:
https://www.aliexpress.com/item/1005002025039837.html
Just doubting if adding strength to this diff housing will cause other parts like the chassis to be damaged earlier.
Hope your rightmate, will give it a try, thanksThere is a simple trick that will increase the strength of the stock diff. Just use longer screws and capture the back with nuts.
In some cases you have to drill out the hole further (2.4mm drill).
I have a hard time justifying the cost of the alu diffs, they are roughly 8:1 and I haven't broken 8 diffs in all of my bashing.
You will improve your driving skills as well and these type of damages will decline.
