Talion Rpm hd wing mount 81802
Grocery Ninja
Michigan
  1. Talion EXB
Has anyone used this wing mount on their Talion exb? Description says it works but it won't fit properly because the holes in the exb shock tower aren't quite large enough. I'm wondering if I got a mislabled package or they changed the tower. Looks like I can modify the arms to make it work if I have too.
Cut twice, measure once 😉
Once you break those get yourself a set from @3d-rc.myshopify.com.
Those fit and will be your last set to buy. Almost bullet proof.
Don’t forget to use your discount code: Arrma forum
Thank you so much for the kind words🥰
I got it installed. I ended up having to cut the notches a little bigger than I had hoped but it seems really solid.
I'm loving the way the #3dRC Low Profile mount looks on my Kraton-to-Talion build with the original Talion wing... Even though the wing is already beat up. I turned the uprights forward to get it closer to the tower.
I'm thinking of getting another one in white to match the front bumper spring & moving this one to my Typhon.
