Nitr0EngiEx
Guys, I am confused and frustrated. My stock servo stripped gears so all of my research pointed me to savox 1210sg.
I bought one with castle bec and cap pack, installed both set to 7.4v. Worked fine for like 3 packs. I went to bash at the beach, my favorite spot and my car kept browning out when I guess I would turn.
This escalated until the car died completely.
Process of elimination :
1.) Unhooked bec, it was really hot, probably overworked since servo was shorted, hooked up power supply And battery instead, receiver would flash red really fast. Unhook bec did nothing, bec working fine problem still persist
2.) Unhook motor from esc, did nothing to help
3.) Unhook fans from receiver, no change still shorted
4.) Unhook esc from receiver, no changes still shorted receiver
5.) Unhook servo, receiver gets solid link light and stops shorting. Problem found
6.) Reconnect castle bec, esc, motor, fans, all of it works normal without servo connected.
7.) Reconnect servo, shorts everything out again.
So through this process I found my brand new savox servo is freaking fried. Like really badly fried to the point its shorting out my entire car. I'm very frustrated this thing was supposed to be the most amazing servo.
Even though it says high voltage I wonder if it really isn't rated for it and the 7.4v did it in.
One of the key things that helped me figure this out besides the process of elimination was my power supply when hooked up it would turn off saying underpowered which means it was hitting the max 10 amp at 7.4v and shut off. When your instant hitting a max amp cut off as soon as you turn on receiver there is something wrong. 10a is allot of current.
This means the servo was demanding over 10 amps draw just by turning it on, connecting it, that's really really shorted
