- BigRock 4x4
- Outcast EXB
- Senton 3s
Hey Bashers! I am building a 4S Senton. Starting with my son's V3. I could use a little help. I am upgrading the diffs with HR steel gears redoing the slipper clutch and driveshafts. And beefing everything up around the chassis. (Build parts list below).
My questions are:
1. 4S Motor ESC combo? Say what you want I like spektrum so far. Looking at the 130A esc Spektrum - SPMXSE1130 with either the Spektrum - SPMXSM1000 3150KV 4pole (which I think is the same as Stock?) or the Arrma BLX 3668 2400KV motor. This is my sons truck so he will probably run 3S most of the time but, I would like the option to run 4S. Even if i gear it down a little. Thoughts???
2. I have a lot of slop in the steering and rod ends. Any good ideas on metal replacements?
3. Recommendations on a starting point for shock and diff oil weights?
Thanks for any advice! More pictures to come with updates when assembling.
Here is my build list so far.
ARRMA SENTON 3S V3 BLX 4S CONVERSION BUILD
Front / Rear Differentials
Hot Racing Aluminum Diff case #ATF11A01 X2
Hot Racing Steel Helical Ring/Pinion Gear #ATF9337 X2
Hot Racing Aluminum Diff Yoke #ATF11Y02 X2
Hot Racing HP CV Driveshafts #ATF288RC X2
??? Diff Oil ???
Power Module / ESC
?? ARRMA RC BLX3668 2400Kv 4 Pole 4S Motor #ARA390265 X1
?? Spektrum Firma 3150KV 4 pole BL 4S Motor #SPMXSM1000 X1
Spektrum 130A Brushless Smart ESC, 2S-4S, #SPMXSE1130 X1
Hot Racing HD motor mount #ATF18MX01 X1
Surpass Hobby Dual 30mm fan / heat sink X1
Slipper Clutch / Drive shaft
Hot Racing OT 57t Mod 0.8 Steel Spur Gear #STFF257N X1
Hot Racing Aluminum OT Slipper Clutch Pad #ATF15HN X4
Hot Racing Aluminum Slider Driveshaft LWB #ATF125HL02 X1
Tires / Wheels / Suspension
Fast Eddy Sealed Ball bearing complete set # X1
Hot racing 12mm Aluminum Wheel Hub Adapter #ATF10A02 X1
Pro Line Racing Badlands MX28 Belted 2.8 tires #PRO1017410 X2
Suspension / Chassis
DS Servos 25KG Metal Gear Waterproof Servo #DS3225 X!
DJX Aluminum 25T Servo Saver X1
ARRCat Aluminum Pivot ball set (Blue) X1
Hot Racing Aluminum rear hubs #ATF2201 X1
Hot Racing Aluminum Front hubs caster blocks #ATF1901 X1
Hot Racing 105mm Aluminum Big Bore Shocks #TD105X06 X1
Hot Racing 120mm Aluminum Big Bore Shocks #TD120X06 X1
??? Shock Oil ???
Body
Pro Line Racing 1/10 Monster Fusion Body #PRO349817 X1
Pro Line Racing 1/10 Extended F/R Body Mounts #PRO637500 X1
ARRMA RC ARRMA wing mount #ARAC9602 X1
ARRMA RC ARRMA 1/8 rear wing typhon #ARA480016 X1
Apex RC 4 LED F/R Light Kit w/ Bezels #9012 X2
My questions are:
??? Diff Oil ???
Power Module / ESC
??? Shock Oil ???
Body
