Tgrenfell
So, I've had the Senton Mega brushed for 5 days. This is actually my second in 5 days. The first one not only burned the motor but completely trashed the spur in 4 batteries. I ran that one rtr which I guess was a mistake. This one, the replacement, I carefully set the mesh as it was pushed directly gear to gear, no space at all, from the factory. I also loosened the slipper a bit. These aren't rtr unless someone wants to wait on a replacement! I think I have it set up ok, but now after 1 battery I decided to stop and check it out. The motor mount had a surprisingly large amount of sand in there. Packed between the teeth of the spur! Am I doing something wrong or is this a HUGE design flaw? It doesn't matter how well the mesh and clutch are set if there's sand packed between the plastic teeth! Help!
