jose samayoa
I got bigger tires and I ran my senton for 10 minutes on 3s and stripped my sour gear(plastic). What’s the best gearing ratio to go with? And what brand metal spur gear
Welcome to AF!I got bigger tires and I ran my senton for 10 minutes on 3s and stripped my sour gear(plastic). What’s the best gearing ratio to go with? And what brand metal spur gear
Spektrum 85 smart esc and 4000kv motorWelcome to AF!
I would check the motor mount and see if it’s bent.
Gearing wise, I would go 13t pinion.
Those large tires might be rough on the drivetrain, be sure to set your slipper correctly.
Hot racing metal spur is decent and don’t need extra slipper pads.
What electronics are you running?
That is very high kv for a Senton 3s with mt tires.Spektrum 85 smart esc and 4000kv motor
It was a mega, all I did was upgrade the slipper to a 3s, made it brushless and wheels and tires. Would I need a blx motor mountWithin 10 minutes...?
Chewed out what looks like ALL the teeth around it.
You need to double check the mesh next time.
Something went very wrong there, could be your motor screw came loose or the motor plate is slightly bent.
So get a metal motor mount and should I get a metal spur gear? And lower the pinion gear? I have a 17t I heard to run a 15tIf it still has the plastic motor mount, then yeah, you should upgrade to the metal motor mount.
Will the blx mount fit in my mega motor housing?Yes, you will need a 3s motor mount. The plastic mega mount will not hold up. No real need for the metal spur. Composite holds up just fine on 3s. Replacement spur is around $5-$7.
So try a 15t firstwith my stock big rock with the 3200kv, i ran the 18T, up from the 15 or 16. I would assume with the 4000kv, you wouldn't want to go higher than 15 and maybe even lower depending on cogging and motor temp.
Do I have to buy this whole set or just the motor mount for my mega motor housing?Yup. Just use the pull tab and remove the housing. 3s one snaps right in. Direct replacement.
I would also recommend getting the center driveshaft support bearing. High speeds and the long chassis will cause the center shaft to vibrate and come loose. https://www.ebay.com/p/13022965621
Whole set. While the back of the mega spur case is the same the front of it isn’t.Do I have to buy this whole set or just the motor mount for my mega motor housing?
So the whole set will work perfectly will the blx slipper. Cause I’m about to order all my parts and I want to figure out what I needWhole set. While the back of the mega spur case is the same the front of it isn’t.
You want the new thicker mount off the vendetta, 3s infraction and new 4s line. Go to Jennysrc.com and check to see if in stock.So the whole set will work perfectly will the blx slipper. Cause I’m about to order all my parts and I want to figure out what I need
You have to check each model as they don’t lump them all together.Sold out sadly…
