I've watched the video a couple more times and it seems as tho the centrifugal force of your wheels is over powering your servo saver. your wheels don't turn much and the movement is slow and not abrupt. With the truck turned on move the wheels from side to side with your hands and see how much resistance you have. Your problem may be no more than a warren or misadjusted servo saver.
I do not have that model to know if it comes with AVC. If it does, this is the correct way to disable the AVC correctly and then you can test to see if AVC is part of the issue...Hi all!
Does anyone know why my Outcast is turning wheels left or right when doing backflip?
Is it the AVC kicking in? I have the dial turned all the way down. Should I rebind turning it off completely?
Video:
Thanks!
