ZachSadlieer
- Senton 6s
Any suggestions for a new servo for the senton. And cheap 3s battery’s
That’s only a 15kg servo. Kind of weak. ??https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/302342560359
I personally like this servo. It has a load of torque and speed, perfect for the 3S trucks. And for lipos, I recommend a HRB 6000MAH 3S 50C. They fit perfectly if you take out one of the limiters, they are inexpensive, and I get about 35-40 Mins on one battery if I can manage to not break it ?
Hm I’ve always thought it was more... it whips my MX28s around no problem?That’s only a 15kg servo. Kind of weak. ??
What's the coreless bit about?View attachment 70440
This one ds3225sg coreless
So what's your favourite of the three?I actually own both. If there’s a difference it’s beyond my ability to notice. I have the blue in the Typhon 3S and a red in the K4S and Granite. I have a JX Eco in the Typhon 6S and that sucker is faaaaast ??
Well the JX isn’t waterproof so I wouldn’t bash with that and the two DS 25kg are both fine. The blue one I have in my speed runner and I turn down the expo to like 50% anyways so really any servo would probably be fine. The truck both have the red ones and work great. I have issues with servo savers more than I do with servos.So what's your favourite of the three?
What happens with the savers? I still have the 123 in there. Hoping it will be OK.Well the JX isn’t waterproof so I wouldn’t bash with that and the two DS 25kg are both fine. The blue one I have in my speed runner and I turn down the expo to like 50% anyways so really any servo would probably be fine. The truck both have the red ones and work great. I have issues with servo savers more than I do with servos.
Can’t say for sure but it seems like the spring inside got stretched to the point it would spin 90 degrees freelyWhat happens with the savers? I still have the 123 in there. Hoping it will be OK.
Hmm, well I'll try what I have and replace it if I kill it, I guess.Can’t say for sure but it seems like the spring inside got stretched to the point it would spin 90 degrees freely
