Iamtheoutcast
Yeah it sucks worst part about it is it's my steering hand. But has given me time to work on a couple projects i've had sitting on the shelf. Switched to google voice to make things a little less painful to read.
Interesting!! Yes I was doing wheelies a lot. Is the 300k good in rough trails?
Ya thank you
Was this with the 300k or the 100?I tested the car. The center diff still got hot. I think it is because of my driving still. I may try to remove the 2 shims behind the 2 big gears. Just to make sure.
Went through and set my default to google instead of bixby.
Had this exact same thing happen to me, my CD would get so hot that it heated up my pinion gear and caused it to come loose. I removed my CD and discovered that I had a bearing that was binding up after a few minutes of running it. Replaced both bearings with fast eddy bearings, re-installed making sure that the mesh between pinion and spur was correct and problem was solved. My CD is also shimmed, not sure about the shims you are using but when I did mine I tested for any binding before I filled it with fluid. I assembled it with only two screws snugly and checked that the gears didn't bind. The silicone can hide this that's why I checked them dry first. Hope you get it figured out, took me about two days to figure mine out.........lolAnother update. I returned all the shims and test it. I still got the same heat. I'm going to add some thick oil (like @Jerry-rigged said) and see how it goes. Thanks everyone.
