I always enjoy your replies, you always have some worthwhile knowledge to offer.Verticle or Flat as feasible on your specific rig. Generally it is best to keep wires secure enough so they don't flop around when bashing hard. That is how the solder joints weaken over time, then break. Wire ties and Heatshrink is always the way to go. Motor leads usually come apart at some point.
Below, I always drill a hole at the 2 blue dots and place a wire tie through it to keep the 3 wires in place.. The motor wires usually pop out here if you don't.
That's awesome, thanks will do for sure.Verticle or Flat as feasible on your specific rig. Generally it is best to keep wires secure enough so they don't flop around when bashing hard. That is how the solder joints weaken over time, then break. Wire ties and Heatshrink is always the way to go. Motor leads usually come apart at some point.
For sure, I had electrical tape on em and the still popped free after today's session so heat resistant shrink tube is clutch!!Stealing the heat shrink on wires idea. Thanks!
Get the marine type with adhesive if you canFor sure, I had electrical tape on em and the still popped free after today's session so heat resistant shrink tube is clutch!!
What size?Get the marine type with adhesive if you can
What size?First bash session with the shrink wrapped wires and the heat from the motor only solidified the wrap further very cool idea.
