ridgehead44
- Granite
Hey All,
Good morning and TGIF! After a year away from the hobby, I've finally got the opportunity to dive back in. Last time I ran I had the slipper too tight and it blew up my rear drive shaft. Since then I've watched several videos online which show how to correctly set the slipper. I want to give the truck a couple quick rips up and down the street tonight, to make sure the slipper's set correctly.
Are there any signs I can watch for, which would indicate the slipper is too tight/too loose? What sort of sounds/vehicle behavior should I be on the watch for? Any input is much appreciated. Thank you in advance!
