Reason I ask is because I have 2 batteries which are advertised at 155mm and 157mm long and they barely fit. One is also advertised at 49mm wide and the other 50mm wide, yet the 50mm wide one fits better. This SMC is advertised as 165mm in length. I don't trust the specs for the size.Thumbs up here!!! I have a few of them... and have a few more now... just tested a new pair in the dbxl-e on 12s...and yes they will fit all arrma 6s vehicles....and good customer service as well.... Mike
I ordered one while they are on sale. I will post a photo once I get it.I'll get exact numbers on the new ones tomorrow... I know they fit all of the arrmas.. even my 4s batteries fit everything...and they are all about the same size
We need those numbers bro!I'll get exact numbers on the new ones tomorrow... I know they fit all of the arrmas.. even my 4s batteries fit everything...and they are all about the same size
I get mine tomorrow so I may have the numbers up first lol. I hope it fits.We need those numbers bro!
Awesome! 155 should be perfect. Thanks155mm long 60mm tall 45mm wide
Or 8 1/4" long 2 3/8 tall 1 3/4 wide... Mike
Since you removed the plastic top part on the battery tray you can easily just turn the battery around. =D
The wire would then be pinched between the tray and the battery. I tried and it does not fit well that way and could damage the wires after some time.Since you removed the plastic top part on the battery tray you can easily just turn the battery around. =D
Can't you rotate the battery so the wires are coming out of the top? maybe I'm seeing it wrong in my head lol.The wire would then be pinched between the tray and the battery. I tried and it does not fit well that way and could damage the wires after some time.
I may order a second one and see if he can make the leads about an inch longer or so.
No, It would be too wide for the tray if I rotated it that way.Can't you rotate the battery so the wires are coming out of the top? maybe I'm seeing it wrong in my head lol.
I think he meant just to flip it upside down, so the label is on the bottom?No, It would be too wide for the tray if I rotated it that way.
That's exactly what I meant.I think he meant just to flip it upside down, so the label is on the bottom?
That would put the wires on the other side but not the top still and they do not fit any better that way either.I think he meant just to flip it upside down, so the label is on the bottom?
