Not unless you widen the arms and add wider offset 17mm hexes.Would the stock kraton 4s wheels work?
Thank you, this is what I will do. Good tip on the HR adapters.Not unless you widen the arms and add wider offset 17mm hexes.
I would still recommend the HR 17mm x 10mm offset hexes so you can use 17mm wheels. This will open up your choices a lot. My favorite is the MX28 Badlands from Proline. You can see them both in the pic below on my Granite. They really work well on every surface I’ve tried to date. Perfect size and weight too.
