ScaleJunkie
This is unfortunate, and I'm sorry to hear you are having a recurring problem/losing faith in Arrma. It sounds to me that the slipper being too tight is what is causing your issue. I think you have ruled out bearing play from what you have said. As stated before, a tiny dab of threadlock on the tension screw for the slipper should solve your problem, I would use blue so that it doesn't set up so hard that it's a PITA get back apart when time to change pads.As stated earlier in this thread my slipper doesn't stay tight if I set it any less than a hair from fully tight. So what would you recommend I do since you think the spurs are getting torn up due to the slipper being too tight? Should I just stop driving the car every 5-10 minutes when the slipper comes loose and call it a day? The whole slipper assembly is basically brand new it has like 3-4 batteries through it. Everybody seems to be able to tell me they think I'm wrong but can't tell me why my ARRMA TOUGH vehicle isn't so arrma tough. I literally tore the whole thing apart last night to install the Jimsbearings kit and found nothing. The motor mount isn't bent, I found nothing. Some of you are ARRMA fanboys and I am beginning to hate this brand. Contacted support and they told me to send them my torn up spur gear in order to get a replacement. I told them I would happily send all 7 of my torn up gears if they paid shipping, but of course they wont. Somebody take this POS of my hands
