baz2011uk
hi just come back from a little run about and just before i come back the steering locked up to the left
no hard bashing just a few runs up and down the tarmac no impacts at all so no real reason for it to happen
its a v3 kraton
i have stripped it back and seems to be an issue with the servo i think pretty new to rc had a savage 6/7 years ago so i have a little knowledge from back then
all connections are fine and no broken wires either
i have reset all end points just in case and also checked the trims
i have removed the servo and with nothing connected apart from power and the horn if i turn right there is no input if i turn left it works but wont turn right at any point
if i manually turn it fully right when off when turning on it will centre itself
if i manually turn it fully left when off when turning on it will not centre itself
the servo seems fine tho no grinding like i have stripped a gear
seems strange any suggestions that i can try out to pin point what the issue maybe
its a v3 kraton
