- Outcast 8s
- Typhon 6s
- Thread starter
- #21
Not exactly sure what you mean by "let out the screw" but if you didn't mean these, you can crank down your droop screws to lower the ride height of the car while maintaining a lot of shock pre-load. On the front suspension, the droop screw is kind of hidden on the lower arm right next to the bulkhead. It can be helpful to drill a 3-4mm hole in the upper suspension arm just above the droop screw to make accessing and adjusting droop easier than trying to come in from behind at a steep angle (though it works in a pinch).View attachment 273273getting everything mocked up to see where it goes. Got sum diff cups from scorched coming also think my bumper is on upside down. How do I get my car to sit lower its sitting to high. Ive already let out the screw don't know what else to do so all advice is greatly appreciated
Yeah thats the screw I was referring to the name just slipped my mind at the moment. But thanks anywayNot exactly sure what you mean by "let out the screw" but if you didn't mean these, you can crank down your droop screws to lower the ride height of the car while maintaining a lot of shock pre-load. On the front suspension, the droop screw is kind of hidden on the lower arm right next to the bulkhead. It can be helpful to drill a 3-4mm hole in the upper suspension arm just above the droop screw to make accessing and adjusting droop easier than trying to come in from behind at a steep angle (though it works in a pinch).
I suspected as much, but just wanted to be sure.Yeah thats the screw I was referring to the name just slipped my mind at the moment. But thanks anyway
Thnx im super excited to see here up and runningLooking good man!!! Can't wait to see that thing blast off!!
Sure. They may come off with a bad crash, but holds em otherwise.Is it possible to attach my lipos with dual lock. Will it hold
I would try resetting the transmitter to default or use the next vehicle memory slot, bind the receiver and then calibrate the ESC (take the wheels off the car this time ). Report back and let us know how it went.Ok still have zero idea of what I did but now the steering started working then I started messing with the speed trim on the side of the remote and the throttle started working. So I turned it off again to see if it took. After turning it back on the steering still worked but no throttle. So I started Messing with the throttle trim again and it started working again but it starts rolling on its on when I do it that way and I have to turn the trim until it stops spinning and the throttle works again. Any ideas please help lol I've done everything I can think of and can't find any more info online. A lil info its a futaba 4m transmitter
Ok took her out on her maiden voyage just now my GPS was dead so couldn't get my speed but got it dialed in better, got the throttle reversed and trimmed the steering. I wasn't ready for that speed lol it scared me a lil and I don't think I was even going that fast probably 60 need to get my braces on before I try anything really. After I charge my gps ill do a quick lil run and get back to ya. Also my batteries seem to run down really fast is that normal. I wasn't out there that long maybe made 6 passes or so
She was nice and cool very happy with this motor, does alot better than the 1100kv but then again it's pushing a outcast 8s so yeah. Also I heard you suppose to charge the srd smd lipos differently like only charging at 1 to 3 c but ibdont know what thats means an you help pleaseSpeed gearing sucks big power.
Just make sure you check temps between runs and don't burn anything up.
Be careful
