- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
The shortest way to describe it is that if the battery is 5,000 mAh then set the charger to 5 amps.She was nice and cool very happy with this motor, does alot better than the 1100kv but then again it's pushing a outcast 8s so yeah. Also I heard you suppose to charge the srd smd lipos differently like only charging at 1 to 3 c but ibdont know what thats means an you help please
If it was 6,500 mAh, then set it to 6.5 amps.
If you charge at higher amperage than that ratio then it will run shorter and longer-term "might" shorten the life of the lipo.
