Yes, you can either get the Arrma one (need an extra slipper pad) or the Hot racing one which is cheaper, and nothing extra is needed.O dear yes you are right gear is stripped
Can you get metal ones ?
Also can you tell me the part numbers I need please ?
Thank you very much
Can you give me the AR numbers for what I need please ?Yes, you can either get the Arrma one (need an extra slipper pad) or the Hot racing one which is cheaper, and nothing extra is needed.
Hot Racing one: https://www.amainhobbies.com/hot-ra...spur-gear-57t-hrasatf257/p948701#tab-feedback
Check if your motor mount bent also.
Yes.Can you give me the AR numbers for what I need please ?
Thank you
Thanks! I have just ordered this ..Yes.
Spur is ARA310945
Slipper pads (4pcs) is ARA310908
£12.09 36%OFF | 57T 0.8Mod Slipper Clutch Spur Gear ARA310949 For 1/10 Arrma Senton Granite Vorteks Big Rock 1/8 Typhon Upgrades PartsThanks! I have just ordered this ..
Will it do the job also please ?
Thank you
You can use the existing one as long as it's not stripped.£12.09 36%OFF | 57T 0.8Mod Slipper Clutch Spur Gear ARA310949 For 1/10 Arrma Senton Granite Vorteks Big Rock 1/8 Typhon Upgrades Parts
https://a.aliexpress.com/_mqY5vik
Will I also need to order a pinion gear at the same time or can I use existing one please ?
