nuclearjediW80
- Felony
- Infraction
- Kraton 6s
- Senton 6s
I keep seeing people shimming the outdrives “on the outside surface of the bearing. Correct me if im wrong, but that shim should be between the bearing and the bevel gear. If the the o.d. of the shim doesn't make contact with the diff housing nest, then it literally does you no good. It should he between the bearing and the gear. Im having ALL kinds of problems with the limited slip diff. Im grabbin some HR housings today at work, so im hoping its just the deflection from the plastic housing. I don't want to lose the extra gear width, but i had better luck when a ran the old style 6s diffs in my EXB. Btw, the hydraulic clutch plates....i mean..am i right....are they hyd plates? Like spin creates hyd pressure thus creating “push” on the gear?? Im a ex machine builder/machinist/pipefitter/tool & die maker and thats what they look like they do..but idfk for sure. I AM VERY tired of rebuilding diffs though, and ready to try about anything. Shims=yes, bearings=yes, grease=yes,correct fitment=yes.......two ir three sets if batteries and diffs are toast=YES! and jsyk, it might be worse with paddles or trenchers, but i like runnin the revo anaconda tires for most stuff and stock some times..and it just doesn't matter. Im NOT impressed with the “new” diff setup at all, but feel like i might be missing something aswell
