Mr.Vylan
If you're in control, you're not going fast enough
- Bay Area, California
- Felony
- Kraton 6s
- Senton 6s
- Senton 3s
I broke the rear suspension arm (AR330516) on my Senton.
Since I'm new to the hobby, my question is in regards to replacement options. I'm not sure if this is a common part to fail. I was not bashing and it was a direct hit into a metal patio chair. I guess it was simply a perfect hit in the right location of the arm. It also broke the shock eyelet at the same time.
- Should I replace it with the stock part?
- Should I replace it with an aftermarket part?
- If yes, what manufacturer should I look at?
- And if yes, should I replace the front and rear?
