Motor came to slow sieze up, appears I did bend shaft slightly enough to finally stop the motor after busting up gears.got a 2000kv motor coming ,be starting over new pinon,spur gear too now that they are worn unevenly.
Good to hear. It just sometimes you sound too excited as if you just started in RC, thats my perception.
I drive mine in a bashing spot near my house, it has grassy flat sections, a few rollin hills, some dirt area and a clean straightway.
For those all out days I break out the 1/5th scale and on into a public school field;
or this one for when I am in jump mode mood.
What is the name of this rubber?for now just wanted to show the new shoes for the Talion.
Thanks.The tires are high quality, a little on the soft side.
Although I scored this vintage rc and have been silly tweaking it for the last week.
Look mean with those huge tires on it! With how cheap they are, I probably should pick up a set for my son's Kraton.
V1 & V2 Talion > V3 & V4 all day every day bro.
Have you ever had those tires off the rims? I had picked up the "fangs" tires from Nitrorcx and when I removed them from the wheels the "foam" wasn't even foam it was it was some sort of fabric.
