- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
This is another big perk of the castle data logs. During a run you voltage will sag alot. Larger batteries will help. Fastest guys often run 2 of them in parallel to give 10000mAh or 12000mAhOk, here is my next "I'm a noob Speed Runner" question.
I see many of you experienced Speed Runners using large capacity batteries, i.e. 5000 - 6000 mAh. It is my understanding that capacity on really help duration of time you can run. If you are only running for 1 to 3 runs, why not use a 4000, 3000, or even lower capacity battery with the same specs? Voltage and discharge rate should be the same, no? Is there some other advantage to using these high capacity batteries?
Sorry if I am missing the obvious answer, but I always have a need to fully understand things
