I run the same tire on mine. Best tires I’ve ever owned. I had to grind the fake lug nuts down to get a hub wrench on mine. You won’t regret the money spent. Great grip no ballooning and the rubber doesn’t seem to wear down at all.
i need those stainless insertsWhat did you expect?
They are not the CH 2 stocker wheels.
No help here with this issue. Is what it is. What are you looking for? A metal insert molded into every aftermarket wheel.
Stay with the stocker wheels it it matters to you.
Perhaps it's not even much of an issue at that.
Don't over think always needing a metal insert.....
>>>from the picture, looks like you will need to drill out that new wheel for it to even fit the 8s Hex adapter. It looks wrong. Wrong wheels??? IDK.
I think you made an uninformed purchase there. Hope I am wrong, for your benefit.
I'll let others chime in.....
The wheels on the right don’t look like they’d fit the car which the wheels on the left came off. The centre holes are different diameters.nobody on this forum has these wheels on there kraton,i just need those steel inserts.wheel on the left
Agreed, I run these on O8s & K8s. Bore out the center hole and grind/machine the fake lug nuts. Don't worry about the steel insert.I run the same tire on mine. Best tires I’ve ever owned. I had to grind the fake lug nuts down to get a hub wrench on mine. You won’t regret the money spent. Great grip no ballooning and the rubber doesn’t seem to wear down at all.
yes im talking about the red ring
ok im going to try this fixAgreed, I run these on O8s & K8s. Bore out the center hole and grind/machine the fake lug nuts. Don't worry about the steel insert.
