To spool or not to spool that is the question
Sirkensirlot
Plymouth UK
  1. Infraction
  2. Kraton EXB
Hi i have just got a TP power 1570 kv 4050 motor for my v2 infraction, going to be running on 6 & 8s using a max 6 esc until I can get hold of a mamba monster x { none in the UK at the moment } I do a lot of hooning with the odd speed run & a bit of drag . will a spool be ok or am I better using thicker diff oil :rolleyes:(y)
If you are not strictly speed running, then I would recommend thicker diff fluid.
Thanks for your reply. I'm running 500k in the metal armma diff as the plastic one failed got 2 more metal arrma diffs on order for r/f any tips on oil for f/ r diffs :)(y)
